2320 mmm & clearance
/ 2320 mmm & clearance #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
Just read the thread about clearance problems with JD belly mowers. Are there any clearance issues with a MMM on the 2320? Thanks for input--hoping to get a 2320 this year or next.
/ 2320 mmm & clearance #2
What do you mean by clearance issues?
See the thread about 5 below this one RE: Use care when buying a JD belly mower---he's talkiing about mower clearance and getting stuck in uneven terrain.
/ 2320 mmm & clearance #4
Overall, I feel the deck in it's lift height and ability to take on and off is outstanding. Also, I find the mow quality to be very good. However, I assume you are asking about the wheels/gouging into the turf? Personally, I have not experienced this, but I do run my "wheels on the four post" a bit higher than recommended, so you will get a little uneven cut if you approach a hill side ways, but I have yet to get the wheel in the correct position using this setting and it tends to line-up in the correct position before this happens. :D
/ 2320 mmm & clearance #5
No clearance issues yet with my 62D mmm. Does a nice job on my yard and I have not had the gouging problem yet either.
LINCOLN ELECTRIC POWER MIC WELDER SETUP (A67714)
LINCOLN ELECTRIC...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Unused 2023 Cross Tech Brushwolf Alpha XP 74in. Brush Cutter Skid Steer Attachment (A66734)
Unused 2023 Cross...
AIR OPERATED OIL PUMP APROX 200 GALLON TANK (A67714)
AIR OPERATED OIL...
JOHN DEERE 9420R ARTICULATING TRACTOR (A65057)
JOHN DEERE 9420R...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
