2320 Drive Shaft U Joint blew up.
   / 2320 Drive Shaft U Joint blew up. #21
Glad to hear they are helping with the costs, I think it is fair also since it is out of warranty. It is nice to hear of a company doing something to help for a change. I agree it was a mistake on their part by not having it in the book but so many just use the excuse that the warranty is up and leave you with the mess. Also good the dealer is trying to help out some!
   / 2320 Drive Shaft U Joint blew up. #22
This is the first time I've heard of this access. I've been trying to figure out how to lube mine. Just how much do you have to take off to get at this access door?
In the years past, I have removed the floor and then held the plastic out while I removed the access plate. This year I'm going to try and remove the dash, then the plastic skirt then the plate. Shoot, I may get frustrated enough to even cut a square hole from the plastic skirt large enough to access the cover. This particular joint is spinning constantly if the engine is running. It needs the maintenance probably more than the once a year I give it.
Other guys have had good luck using a needle adapter for the grease gun and holding it onto the Zerk from below. This doesn't work for me, I can even see the joint from below. Another guy removed the original Zerk and replaced it with an angled one pointing toward the engine and he says he can get to it from below.
With the floor pan removed you can see both u-joints. one picture is showing the rear joint and the other picture is looking down the shaft toward the engine at the other u-joint. I've successfully greased the u-joint once by reaching it through this tunnel, but it sire wasn't easy. That's when I found the access cover. The last picture shows the angle the u-joints are operating at. These suckers are not only spinning, but constantly twisting also.
   / 2320 Drive Shaft U Joint blew up. #23
There are other undocumented Zerk's on this tractor also. The one below the floor on the left side brake peddle hinge or joint (near the hydraulic filter), and some have a Zerk on the power steering knuckle and some don't.
Ok thanks. I will check it. If I see nothing in the manual I will make a note and post it in the barn.
Thanks again.
Here is the actual insert:
  • 88233.pdf
Does anyone know if the U Joints are greased from the factory, or is it something the dealer does when the put the tractor together? What about the oil, and hydralic fluid?
If you take that bottom part of the dash off you can get to it. Its like 8 bolts, but the pain is to get off the cotter pins on the brake and throttle lock.
   / 2320 Drive Shaft U Joint blew up. #27
ORCM said:
I'm guessing your manual has this in it. Should be page 36, I think.
It's on that page. It don't say anything about the access cover, it just shows pictures from the under side of the tractor. And the greasing locations.
   / 2320 Drive Shaft U Joint blew up. #28
Just came in from greasing that notorious Zerk. I ended up removing the floor or deck and I'm glad I did it that way. I found a mouse nest tucked away in a inaccessible hidden area. The nest was filled with Mouse Proof pellets! I use them in the building just in case one of those buggers get inside what I thought was a rodent proof pole barn.
One thing I wanted to mention is how hard it is to actually get the Zerk to take grease. It is such a tight fit, and seemingly so sensitive to how how exactly the grease gun tip is position. It is so easy to pump grease, but miss the Zerk altogether or fill the area around the outside and not get any inside the u-joint.
Well, that job is done for this year.:thumbsup:
I thing I read about someone on another forum, buying an adaptor kit was helpfull. Something like this:
[ame=http://www.amazon.com/Lincoln-Lubrication-58000-Lube-Adapter/dp/B000OCKJW8]Amazon.com: Lincoln Lubrication 58000 Lube Adapter Kit: Home Improvement[/ame]
   / 2320 Drive Shaft U Joint blew up. #30
I bought that exact adaptor kit. Didn't really help me much :( I was trying to go from the bottom.
I HAVE to go from underneath because I have a Curtis Hard Cab installed on my 2320. Which means taking the floor/dash off is not possible unless I take the cab off. The cab is not meant to come off :(
I have been toying with the idea of cutting a whole in my floor/dash and making my own access door.
Getting to these Zerks is quite difficult. :(
2020 CATERPILLAR 323 EXCAVATOR (A52709)
2020 CATERPILLAR...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Forklift Safety Basket (A56857)
Forklift Safety...
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
