2320 Draft Links
/ 2320 Draft Links #1
ohio 2320
The new 2320 comes Monday afternoon to replace the 2210. Was wondering where to position the draft links and the lift links connections to hook up the KK 48" tiller and 48" bushhog. Never had the option to move these around before and was just curious where to start at. Thanks.
/ 2320 Draft Links #2
My 2320 came with the links centered in the middle. Its a good location for my blade box, but I borrowed a 5 foot wide old tiller, and I have to adjust the links to accommodate the old tiller. For me its a try and see approach to adjusting.
Welcome to the forum neighbor:D
/ 2320 Draft Links
Thanks for taking the time to reply. Will have to experiment a little to see what works the best then. :D This is a very informative forum. Enjoy it very much.
/ 2320 Draft Links #4
Knowing next to nothing about these CUT's, "experimenting" is my word for the day! You should love your 2320. It is a really cool machine. I guess my biggest gripe is the diesel fuel filler location. My wife has a very difficult time lifting the diesel container, and getting it over to the fill without spilling the diesel all over the hood. I need to come up with a way to help her fill the machine while I am away working. I certainly don't want her to stop cutting the grass!
/ 2320 Draft Links #5
I am having the same issue with my wife filling the tractor as well. I either make sure it is full before I leave or have half-full (optimist here) cans that are easier for her to lift. Do any of you know how long diese will last in one of those larger tanks? May need to look into one of those in the future.
/ 2320 Draft Links
Just got done mowing for the first time, WOW!!!! :) The 2210 was a nice machine but the 2320 is awesome. Was kinda hesitant about the switch but have no doubt that I did the right thing. As far as the diesel fill, I found 300 gal. tank with an electric pump on it, deal of a lifetime- $200.00. Well worth it.:D Looking forward to sharing info for now and in the future on this site.
/ 2320 Draft Links #7
Ohio 2320,
300 gal tank of diesel???? How far up in OHIO are you, and think I can tram by machine up for a fill-up?:D
UpstateNY,
What larger tank? Mean the one on the tractor? I might be interested.:rolleyes:
Pete in Kentucky
/ 2320 Draft Links #8
I made the same trade in the spring. The 2320 is alot more tractor than the 2210. I also really like the drive over deck & being able to transport the deck with the 3pt hitch. It was always a pain to pull the deck from under the 2210 & then get it moved from the shop to the barn after end of season service & cleanup.
/ 2320 Draft Links #9
The 2320 is indeed a pain to refuel with a can. Seems like there was a thread on TBN about small fuel transfer pumps but I have not searched for it yet. Seems to me that is the ticket although the wives may not like anything that requires very much rigging. I had intended to research the pump transfer option but have not gotten back to it.
/ 2320 Draft Links #10
Sorry about that I guess it was misleading. Not a larger tank on the 2320. I was asking about the large stationary diesel tanks to fill your tractor from. I was just curious how long diesel would last in one of those. Not sure I would 300 gallons in a timely manner. But a 100 gallon tank may be of use if it wan't too costly. Just checkin'.
/ 2320 Draft Links #11
Just came back from walking through Northern Tool store here in Fort Myers Florida. They have a 100 gallon diesel tank (yellow plastic) with a gravity flow fill. Problem I see is you would have to raise the tank high enough to get gravity to do the work. Then comes the problem of refilling the 100 gal tank. They also had a nice 25 gallon tank (steel), but it also had a gravity fill.
I think I'll stick with tramming up to Ohio's 300 gal tank for fill ups! Are CUT's allowed on the Interstates?:eek:
/ 2320 Draft Links
BigD9 only could afford 100 Gal. of diesel to put in the 300 Gal. tank for the time being. Filled the tank for the first time tonight, and the foam from the fill up really pops out of the fill neck. Have to really keep an eye on that. Dug rocks along the side of the barn to replace some rotted wood today, smoothed some dirt to plant some grass seed, and my daughter ran the bushhog for a little while today. Pretty good workout today, man this 2320 is a workhorse of a machine. :D Really saved a lot of back pain today. Can't wait to mow tomorrow. :) Lift links seem to be working out in the middle position.
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2022 John Deere 317G (A64126)
2022 John Deere...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
2017 Maserati Ghibli Sedan (A61574)
2017 Maserati...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
