2320 blower question
/ 2320 blower question #1
Rob-D
Elite Member
Catskills
John Deere 3320
My 47 blower came in with the front attach cables missing an extension. I need to do some blowing and was wondering if I could do it without the ability to raise and lower the blower from the front hitch?
Thanks,
rob
/ 2320 blower question #2
If you wanted to drag the blower I suppose you could but I wouldn't. Although I suppose you could use a tie down to lift it for transport. You'd also have to manually direct the chute.
You can get hoses at a lot of auto/tractor parts stores. They are just hydraulic hoses. Just make sure you get the right thread size/type. There are NPT (tapered fitting, just like pipes) and O-ring type. Even though I put mine together a year ago I can't remember what type it had... ;)
/ 2320 blower question #3
Hey Rob...
I'm assuming you're talking about the hydraulic hoses... not the cables?? I wouldn't push the blower around without lift. If you're referring to the hoses then you can have your dealer or someone else (farm stores, some car parts stores) make the hoses necessary. I had to do that for my blower. I had 4 new hydraulic hoses and ends made up at my JD dealer. They did it while I waited... doesn't take long. Take your hoses all off and take them along... they'll match 'em at the length you need. Have fun blowing snow :D
/ 2320 blower question #4
I agree with above posters - you don't want to drag/push it around - you're just asking for something to be bent.
The dealer should be able to make up a hose or find a larger dealer and have them made - should be a 10 minute deal.
Scott
Thanks everyone.
My dealer is taking care of it and the snow is only a couple of inches at this point so it isn't a big deal. Things should be fine by Monday, the blower is on and ready to go.
/ 2320 blower question #6
Don't forget to check your hydraulic fluid level after dropping on the new hydraulic hoses - they will hold a small amount of fluid. I know I need to add a bit to my 2305 after putting on the new hoses - the fluid is low in the sight window.
Scott
Scott,
I just changed a broken sight glass on my machine and put a little extra oil in the box for the front attach.
Rob
/ 2320 blower question #8
Man I could have used your snow blower on my JD 4200 today, as I spent the afternoon digging out of the Colorado Front Range blizzard of 2006.
My loader worked A-OK; but I just had to find a place to dump the junk, and the first path took the longest as I would scoop snow, move forward, dump, re-scoop, move forward, dump, repeat until I could get to an area to maneuver and dump the junk off to the side.
Oh well, beats shoveling by hand!
You guys sure got a dump!
I didn't want to spend on the blower, would rather have gotten a tiller for next spring but we can get some mean snow up here. I just don't have it anymore to push that walk behind up an down my driveway only to have it drift back over an hour later.
I think blowers are the best. I have a blade but I figure most of its work will be in the dirt.
/ 2320 blower question #10
The melting began today; but it's going to take a while for all the stuff to go away. Usually we get a snowstorm and a couple of days later it's gone. But every few years a low pressure system sets up in the Oklahoma panhandle and we get the up-slope of all that Gulf of Mexico moisture.
Anyway, I've been researching the net for tractor mounted snow blowers. Plenty of three point hitch units out there; but plowing in reverse is not my idea of fun. What few front mounted units I'm finding requires removing the loader, which in my case is no big deal; but the hook up and disconnect looks like a royal pain.
I was hoping to find a loader mounted hydraulic unit where I could pop off the bucket and add the blower easily. According to Deere's specs, my 4200 has 7.3 GPM for implement usage and 4.6 for the steering, which equates to 11.9 GPM total. Most hydraulic powered skid steer blowers require 11 GPM and up to run, and 7.3 GPM implement flow rate isn't going to cut it. I guess if I get real ambitious, I could obtain a skid steer blower, and adapt it to the JD loader bucket connection. A separate hydraulic system could be run via a PTO pump, and all its assorted doo-dads and gew-gaws. Sounds like a fun project; but probably not worth the cost and effort for the few times we get dumped on out here.
So Bambi's loader will do the trick, and as I said before...it beats shoveling by hand.
/ 2320 blower question #12
Ducati996:
Interesting that someone actually makes a pull behind snow blower. I had thoughts of making one; but decided against it because it seemed like putting the cart before the horse to me. With the two big dumps we got recently, I know my 4200 would get bogged down in the snow before the blower could do anything useful. I could see this working on a larger tractor with a lot of ground clearance. Now that the weather guessers think we are done being dumped on, I'll probably put a snow blower into the back of mind. At least I hope we are done being dumped on.
I don't know much about motorcycles; but I'm guessing you are a fan of Ducati bikes.
I don't get it either. Maybe you have to use one. I know that I do everything I can NOT to ride over the snow before I blow it.
/ 2320 blower question #14
I guess you would have to be cautious of how much snow falls so it dosent get too deep - I like it over the standard 3pt, which gives me neck aches just thinking about it. At least with my machine, the price is as much as the front, so I would only go that way
mjncad,
Yes Iam but the funny thing about picking screen names based on models, is things changes as well as model numbers :)
1206 (A64280)
1206 (A64280)
Ambulance (A61573)
Ambulance (A61573)
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2017 Chevrolet Equinox SUV (A61574)
2017 Chevrolet...
UNUSED WOLVERINE TDB-11-66W-66" BUCKET (A64281)
UNUSED WOLVERINE...
ROTO-FINGER PEA - BEAN SHELLER (A63291)
ROTO-FINGER PEA -...
