3-Point Hitch 2320 3pt adjustment - Which is better...
/ 2320 3pt adjustment - Which is better... #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
The LX4 on my 2320 barely lifts off the ground and I want to make some adjustments so I get higher clearance for transport. At full height the blades are only about 6" off the ground.
I can make adjustments in one of two places... 1) I can adjust the LX4 by moving the hitch pin frame into a set of lower holes OR 2) I can raise the 3pt hitch into an upper hole (out of the middle hole)
any suggestions.. thoughts..
Brian
/ 2320 3pt adjustment - Which is better... #2
On my 2305, I used the lower holes for the hitch pins and ended up drilling two extra holes to move the braces further back.
