2310 replacing pto seal
   / 2310 replacing pto seal #1
2310yankee
connecticut
2310 gear drive
I currently have hydraulic fluid leaking from pto shaft while using FEL or lifting rear blower. PTO seal was my first thought.Part is cheap but how difficult is repair?Do I need special tools? Have some mechanical skills but not gifted by any means.Any help greatly appreciated!
   / 2310 replacing pto seal #2
I had the same thing on my 4510. My father in law made a special tool to screw into the old seal to pull it out. We then, as I recall, used a large socket or pipe to push the new seal in. Not too difficult, a cheap part caused alot of leakage and we still do not know why it should have went bad in the first place. When I drained the remainder of the trans. fluild I find what appeared to be the remnants of a copper seal/gasket (?). No problems since but again unsure what that was also.
I now have a very slight leak out of the front wheel drive gear box area. Not alot but messy and annoying. The tractor has less than 1000 hours so I would not think these things should have occurred. Otherwise pretty satisfied for a cab/loader tractor four years old for under $14000.
Thanks for the reply. I was lucky enough that the collar was loose and easy to remove.I was able to tap new collar in using a piece of pipe.All set no leaks!
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2006 Nissan Titan Crew Cab Pickup Truck (A50323)
2006 Nissan Titan...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
