2310 replacing pto seal
/ 2310 replacing pto seal #1
2310yankee
connecticut
2310 gear drive
I currently have hydraulic fluid leaking from pto shaft while using FEL or lifting rear blower. PTO seal was my first thought.Part is cheap but how difficult is repair?Do I need special tools? Have some mechanical skills but not gifted by any means.Any help greatly appreciated!
/ 2310 replacing pto seal #2
I had the same thing on my 4510. My father in law made a special tool to screw into the old seal to pull it out. We then, as I recall, used a large socket or pipe to push the new seal in. Not too difficult, a cheap part caused alot of leakage and we still do not know why it should have went bad in the first place. When I drained the remainder of the trans. fluild I find what appeared to be the remnants of a copper seal/gasket (?). No problems since but again unsure what that was also.
I now have a very slight leak out of the front wheel drive gear box area. Not alot but messy and annoying. The tractor has less than 1000 hours so I would not think these things should have occurred. Otherwise pretty satisfied for a cab/loader tractor four years old for under $14000.
Thanks for the reply. I was lucky enough that the collar was loose and easy to remove.I was able to tap new collar in using a piece of pipe.All set no leaks!
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
NEW HOLLAND 1725 FORD TRACTOR (A65057)
NEW HOLLAND 1725...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
3148 (A63117)
3148 (A63117)
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
