2305 with M806808 solelinoid issue
/ 2305 with M806808 solelinoid issue #1
drenuf
John Deere 2305
Can anyone help with replacing fuel shutoff solenoid on JD 2305
/ 2305 with M806808 solelinoid issue #2
You would probably get better advice in the J.D. forum.
Fuel Shutoff Solenoid Removal and
Installation
1. Park machine safely. See 撤ark Machine Safely on
page 3 in the Safety section.
2. Allow engine to cool.
3. Turn the fuel shut-off valve on the fuel filter/water
separator to the closed position.
4. Remove the air cleaner assembly.
5. Clean around the fuel shutoff solenoid using a parts
cleaning solvent or steam cleaner.
MX35098
6. Disconnect the electrical connector to the fuel shutoff
solenoid.
7. Remove the two solenoid mounting cap screws (A) and
remove solenoid (B) from governor housing.
8. Test fuel solenoid. See 擢uel Shutoff Solenoid Tests in
Electrical section.
9. Installation is in reverse of removal. Check condition of
O-ring on solenoid before installing.
davkir
Thanks for your response ,have new part in hand will let you know how it goes
drenuf
