2305 transmission question
/ 2305 transmission question #1
Number15
Rhea County TN
AC 7600 TTR, Branson 5520CH, Grasshopper 928D2
I was looking at a 2305 with a friend that might purchase it. It has ~320 hours but has sat out in the weather for the last 2 years not really being used. You can tell its been rained on a few times.
Anyway, the sight glass in the transmission had 0 oil in it. I don't know how much actual oil is in there and where the other oil has gone. I could not spy a leak.
Is this an instant deal killer? I told him not to drive it until it was filled and there was no fluid onsite, so we did not see if it even moved.
/ 2305 transmission question #2
2305 doesn't have a stellar reputation as it is. Aluminum rear end is thin around the PTO shaft area and can break fairly easily - so expensive you pretty much have totaled it at that point.
Also has a problematic cooling fan for the tranny that is easy to break and hell to replace.
Personally I would not look serious at this model if unless the price was dirt cheap and it would be used more like a lawnmower with a belly mount deck instead of with the 3pt. PTO attachments. Box blade or some such is fine.
/ 2305 transmission question #3
Are you sure no oil in the sight glass? Trans/hydraulic oil can be so clear it's hard to see.
Yeah, it was for sure empty in the sight glass
Yeah I told him to take a pass. It would have been mostly for mowing but why take a chance. It was in the 8k range as far as price but guy said he was still negotiable.
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
2018 Ford Explorer AWD SUV (A66738)
2018 Ford Explorer...
