2305 Three Point Questions
/ 2305 Three Point Questions #1
ljplum12
Bronze Member
Plano, TX
None
I'm trying to get Cat 1 implements onto my 2305. I cannot get the arms to open wide enough. I called JD support and their answer was to run out the adjustment all the way, which does open it, but not enough, and just makes it lopsided.
Is this thing not meant to hold Cat 1 implements, or am I just missing something?
/ 2305 Three Point Questions #2
buy a quick hitch for the 3pt.
or you could spin the lift pins on the implement to the inside.
or buy shorter lift pins.
/ 2305 Three Point Questions #3
I am not familiar with your tractor but there has to be a way ... can you take pictures of your implement and the rear of your tractor ?
/ 2305 Three Point Questions #4
You have a limited Cat I hitch. It should hook up any Cat I implement but may not have enough lift for some implements. With the sway links loosened, it should spread wide enough. Pictures, and dimensions always help. Make sure the implement is really Cat I. Some are Cat I/Cat II and you have to reverse the pins to change them.
/ 2305 Three Point Questions #5
Make sure your rear tires are on there correctly. On the 2305 and it's almost identical predecessor the 2210 the rear tires can be mounted two different ways for a narrow track or a wide track. Make sure you're set on the wide track. Also make sure that the mid mount mower linkage between the left hand frame and rear tire interfacing with the lower 3-point arm is not binding things up if you happen to have one of these. Even with the limited cat 1, at max adjustment you should be able to mount most cat 1 implements so long as the height allows the three-point travel to pick them up off the ground and they are not heavier than 400 lb or so.
Note also that some cat 1 implements can have the lower mounting pins swapped to point towards each other which may be an option as well
If neither of those give enough travel you'll need to go with the quick hitch option
Full set of pictures included. I tried removing the sway links and it's these points here that are holding me up:
/ 2305 Three Point Questions #7
Looks like you are at the limit. What attachment are you trying to fit up to the 2305? Have pics of them?
Have you looked for a quick attach (iMatch) that will work?
I was trying to use a homemade receiver hitch that I made for my old tractor (Jinma 254). It was a Cat 1 and it worked fine. I thought I made it to Cat 1 specs.. I will look into a quick attach.
/ 2305 Three Point Questions #9
Here is a video of a snowblower on the 3ph of a 2305.
Maybe the model specs for this Frontier will give dimensions of the 3ph attachment.
/ 2305 Three Point Questions #10
John Deere specs for Category I hitch for the heavy duty garden tractors. What are the pins set at on your fabricated homemade hitch?
/ 2305 Three Point Questions #11
Dose it go wider if you disconnect that adjustment ? ... you might have to install pin on the inside of your implements.
/ 2305 Three Point Questions #12
This looks very odd. The 2305 is supposed to be Cat I and should have 27 inches between the lower attachment points. Your picture shows 20 inches, which is the Category 0 dimension. I thought Cat 0 hitches were only on lawn/garden tractors like the X700 series. I have a 2320 which is kind of a 2305 with larger tires and the hitch doesn't seem to look quite like yours.
/ 2305 Three Point Questions #13
These arms look pretty angle in as well ? is it suppose to be like that ?
/ 2305 Three Point Questions #14
Question, are the 2 bottom horizontal arms installed correctly? Maybe at the dealer they were installed incorrectly. I think most of theses tractors come as a kit and then dealer assembled. You could reverse the bottom 2 horizontal arms but you would need to flip them 180 degrees and mount on the opposite sides. See if that doesn't increase the horizontal clearance. Are the vertical arms installed correctly another possibility. Just a suggestion.
/ 2305 Three Point Questions #15
I think Oldtimer may be onto something. I would suggest you try reversing the arms. On my 2320, the ends are not the same. The tractor side has a single angle but the implement side has two angles on it to align the connectors. It also surprises me that you don't seem to have adjustments on the arms. Mine has three different holes to attach the lift links to give different ranges of lift. It makes me even wonder if they are the correct lift arms for the 2305.
If you got this used, I would almost wonder if someone converted it to Category 0 by switching lift arms.
/ 2305 Three Point Questions #17
Oh I see the problem. This happened on my old 2210 as well. The tube with the two chain connection eyes in the center needs to rotate 90° so the connection eyes are facing directly rear. That will give you the additional travel out
