2305 PTO
/ 2305 PTO #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
It appears that you can't operate a chipper with a 2305 because there is no override for the seat saftey switch which turns off the PTO if you're not on the seat.
Do folks use the "Big Brick in the seat" method, or is there an easier way to deal with this issue. Anyone installed a switch that circumvents the seat safety if it's switched on?
Cliff
/ 2305 PTO #2
I jumpered the 2 pairs of wires on my 4010 to allow the under seat button to be used. However, most of the time, I just tie a tension cord from one side of the ROPS across the front of the seat back to the other side of the ROPS. This way, I can raise the chipper/shredder and go to another bunch of brush without having to shut the PTO off.
This tension cord is used to hold the PTO shaft up and out of the way on the chipper/shredder when it is stored. So, it's readily available when I hook up the machine to the PTO.
Ralph
Used Landpride GR1525 Stump Grinder
Used Landpride...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2014 Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
2014 Jacobsen...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
