2305 MMM not lifting
/ 2305 MMM not lifting #1
mattasimms
I am trying to find out (and fix) my 2305 MMM raise and lower function. I was low on hydraulic fluid when mowing stopped (belt came off). Put belt on and added fluid to the tractor. Belt is fine and blades turn fine...I just can not get the deck to raise. My 3pt hitch raises and lowers just fine.
Please help!
MS
/ 2305 MMM not lifting #2
I have read on here about something coming out of adjustment. It has something to do with how the lift is connected to your 3pt. I remember this being covered on here last summer. JC
/ 2305 MMM not lifting #3
Do you have the spreader bar or I-Match installed on the 3PH?
I have a 3pt to a 2"ball for a boat trailer.
/ 2305 MMM not lifting #5
If your lift is not hydraulic, on the left hand 3pt hitch lift arm there is a lever that pushes a rod fwd to a shaft to lift the mower. Check to see if your 3 pt hitch lift arm has slipped past that lever, if the rod is bent or out of adjustment, or if the weld connecting the fitting on that shaft broke. You have to have a spreader bar or iMatch or something to keep the 3 pt hitch lift arms spread far enough apart to catch that lever.
You hit it right on the head. I was pulling a tree yesterday and must have bent the piece that is on the left arm of the 3ph...Now I have to find a way to bend it back. I am sure a vice will do the trick.
Thanks for your help!
MS
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
4' Barnwood Bar Table (A66408)
4' Barnwood Bar...
