2305 hydo filter hangs low
/ 2305 hydo filter hangs low #1
Roadkill95
CT
none now
I have been looking for a tractor for a few months and today I looked @ the JD2305 seems like a nice little tractor.
The only thing I worry about is how low the hydro filter hangs, I can see ripping that off in a heart beat. Do they make a skid plade to cover that?
Local price on these are a little high what JD dealers do you guys use that ship or are close enough to New england to go pick up that do better pricing. I need to price some other local dealers.
Has anyone on here used muttons that runs the adds on here. AnyJD dealers frequent the boards like over @ the kubota boards.
/ 2305 hydo filter hangs low #2
RoadKill,
Have you checked out Farmington Valley Equipment? Jack Wilcox has always done good by me. As for the filter being low, it is one of those things that comes with the low center of gravity. I've never punctured or damaged mine, but I do keep an extra filter and fluid on hand. :) A skid plate could be fabricated, but it would have a hard time accomodating the MMM shaft.
/ 2305 hydo filter hangs low #3
Never had a problem with mine......150 hours.
/ 2305 hydo filter hangs low #4
Does your filter hang low?
Does it wiggle to and fro?
If you hit it with a rock
will it interrupt the flow?
Can you fashion it a guard?
Or is there any other mod?
I haven't heard of the filter being much of a problem on the 2305, the only thing that comes up every so often is the cooling fan getting a stick in it and breaking the blades. I don't know if they've added a better guard but it doesn't stop most people from enjoying the 2305.
/ 2305 hydo filter hangs low #5
I haven't had an issue with mine, but I haven't had it in the woods yet, either! I'd also like to have a skid plate in place of the MMM when I start clearing the woods. But so long as we're careful about what we're running over, it shouldn't be a problem. I guess I've thought of it as one of the drawbacks to having one of the smallest tractors available for the power and capability it has.
/ 2305 hydo filter hangs low #6
Not to scare you off on the 2305 - But you will probably run into more problems with the hydrostatic cooling fan than anything else (unless JD has modified where it is mounted)... A lot of ppl have knocked off a blade or two or three from stuff underneath hitting it..
brian
/ 2305 hydo filter hangs low #7
Jdbower is a poet , and we didn't even know it.....:D
Chris....:)
The dealer said they had a couple fans they replaced and JD paid even out of warranty.
He said they made some changes to protect the fan I saw the fan but didn't really inspect it. The fan is a whole lot higher up than that hydrp filter.
I know kubota BX has a fan issue, and they do not have a factory fix for it but Bro-tec makes a skid plate for that tractor.
If all you can do with this is play on the grass and driveway its not the tractor for me, which is too bad as I like this better than a BX.
I would worry in the woods if you stradle a small rock I think you would take it out.
I may go back today and take another look to see what type of skid plate could be made.
Pehaps Bro-tec will make one for it along with a thumb and ripper for the BH like he has for the BX
/ 2305 hydo filter hangs low #9
I wouldn't think it difficult at all to make a skid plate to hang on the MMM lifts and front support bar. Not that I could do it, but someone with fabricating experience and tools probably wouldn't find it hard. Consider it another implement if you need to be in the woods...
/ 2305 hydo filter hangs low #10
VABlue said:
I <deleted text> Not that I could do it, but someone with fabricating experience and tools probably wouldn't find it hard. <deleted test>.
I hear you on that.. im so envious of the ppl on here that make/modify there own stuff OR more envious of the ppl that have the right equipment/tools for that..
brian
/ 2305 hydo filter hangs low #11
QUOTE]
Classic!
Scott
2021 ROTAIR D185 AIR COMPRESSOR (A65643)
2021 ROTAIR D185...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Gen Eye Pipe Inspection System (A65579)
Gen Eye Pipe...
2022 EZ-GO ELITE...
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
New - Front mount rototiller
New - Front mount...
