2305 handle a 5ft Brushhog?
   / 2305 handle a 5ft Brushhog? #1
wagonguy
western pa
JD 2305
Is 5' brushhog too much or can ths 2305 run it OK? no hills ,(so far) just wonder about weight and lift?
   / 2305 handle a 5ft Brushhog? #3
All bush hogs weigh different.
Will it lift the weight...probabally.
Does it have enough pto HP to use it....Probabally.
Will it be hard to steer without front weights or a loader...definatally.
Would I do it...NO. Id just get a 4' made for the tractor.
   / 2305 handle a 5ft Brushhog? #4
John Deere does not offer a 5 ft for 2305. I would go with
either the Frontier 4 ft or the King Kutter XB designed for SCUTs.
   / 2305 handle a 5ft Brushhog? #5
I run a 5ft. bush hog on my 2305 just fine. I have the loader on the front though. It works just fine but it's quite a load on the tractor to lift and run. Get a 4ft if you care about your tractor.
   / 2305 handle a 5ft Brushhog? #6
So then why are you running a 5 footer?
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2006 John Deere 120C Hydraulic Excavator (A55787)
2006 John Deere...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
