Oil & Fuel 2305 Front axle oil
   / 2305 Front axle oil #1
fdmars
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
Front axle oil is low, went to dealer to get some, he said it unit is shipped from factory w/ 90 weight oil, and they swap it out with hy-gard as it works better over here, looking at the oil in the axle now it does not look like Hy-gard, anyways the question is, is it OK to put Hy-gard in the front axle?
same stuff they use in the rear. Thanks much
Fred
   / 2305 Front axle oil #2
I would pull the owner's manual out and check it. I would follow the book.
D.
   / 2305 Front axle oil #3
Fred
It probably has EP gear oil in it. Hyguard is the easy way at the factory, but check with your dealer.
df
in New England I guess, seems odd to me. Had some left over Hy-gard and wanted to use it, but I agree 2 qts of 90 weight cannot cost much.
   / 2305 Front axle oil #5
Mine was low after 2 years. Haven't see any leaks. I topped it off with 90wt from autoparts store. JD recommends 90 wt. I put in 90 wt. Been fine ever since. Your dealer may be blowing smoke. I'd be leery of what he says n the future... :cool:
   / 2305 Front axle oil #6
I switched my 2210 over to 75W90 mobil 1 gear lube at the 50 hour service. Changed again at 300 hours. Coming up on 500 and working fine.
You can run a dino gear lube if that is your preference.....75W90 whatever.....
   / 2305 Front axle oil #7
My 2305 owner's manual calls for GL-5 rated 80W-90 gear lube in the front axle. So that's what I use. In a colder climate I might consider using a synthetic 75W-90.
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
Eagle Weathervane (A55853)
Eagle Weathervane...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56435)
2020 John Deere...
1991 International 4900 Box Truck (A55315)
1991 International...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
