Oil & Fuel 2305 Front axle oil
   / 2305 Front axle oil #1
fdmars
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
Front axle oil is low, went to dealer to get some, he said it unit is shipped from factory w/ 90 weight oil, and they swap it out with hy-gard as it works better over here, looking at the oil in the axle now it does not look like Hy-gard, anyways the question is, is it OK to put Hy-gard in the front axle?
same stuff they use in the rear. Thanks much
Fred
   / 2305 Front axle oil #2
I would pull the owner's manual out and check it. I would follow the book.
D.
   / 2305 Front axle oil #3
Fred
It probably has EP gear oil in it. Hyguard is the easy way at the factory, but check with your dealer.
df
in New England I guess, seems odd to me. Had some left over Hy-gard and wanted to use it, but I agree 2 qts of 90 weight cannot cost much.
   / 2305 Front axle oil #5
Mine was low after 2 years. Haven't see any leaks. I topped it off with 90wt from autoparts store. JD recommends 90 wt. I put in 90 wt. Been fine ever since. Your dealer may be blowing smoke. I'd be leery of what he says n the future... :cool:
   / 2305 Front axle oil #6
I switched my 2210 over to 75W90 mobil 1 gear lube at the 50 hour service. Changed again at 300 hours. Coming up on 500 and working fine.
You can run a dino gear lube if that is your preference.....75W90 whatever.....
   / 2305 Front axle oil #7
My 2305 owner's manual calls for GL-5 rated 80W-90 gear lube in the front axle. So that's what I use. In a colder climate I might consider using a synthetic 75W-90.
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2021 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
KOMATSU PC138US-10 EXCAVATOR (A52709)
KOMATSU PC138US-10...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2018 Dodge Ram 5500 4x4 Crew Cab Flatbed Service Truck (A55973)
2018 Dodge Ram...
