2305 C/C and RC tips
   / 2305 C/C and RC tips #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
I finally got around to installing the cruise control kit on my 2305. It was pretty strait forward and works well, but there is a problem with the early 2305's. The "forward" pedal on the early models does NOT have the mounting provisions for the kit. The dealer ordered a replacement under warranty and it works just fine. If yours has one spring pin hole it's the early one. The later ones have a longer bushing and have two holes.
I have been experimenting with my new LX-4 and ended up with a fairly comfortable setup. (Our pastures are pretty rough) I run the fronts @ 10 psi and the rears @ 8 with 5 suitcase weights on the front and the loader removed. I use a piece of 1/4 plywood with a piece of foam rubber glued to it under the seat.
Thanks to whoever suggested building a wood support with casters to help install the cutter. GREAT idea!
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
24220 (A56859)
24220 (A56859)
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
