2305 and subsoiler
   / 2305 and subsoiler #11
I'm afraid that the "yellow" full size subsoiler that TSC has would be too large for a 2305. It is about 25" from the tip to the lower pins. I looked at it for use on my larger B2620 Kubota, and decided that I probably just couldn't get it far enough off the ground for transport. I ended up buying the "yellow" middlebuster, and that has worked fine. Now I just need to make a chisel point for it.
   / 2305 and subsoiler #12
I bought the TSC subsoiler to try out and am a little dubious of it, haven't tried it out yet but I am thinking it is too short to do much good. Most of the subsoilers I have used in the past (in the southeast) ran about 24" deep to break thru the hardpan.
I think this thing will only run about 12 to 15" deep on my tractor.
Steve
   / 2305 and subsoiler #13
Steve
What size tractor do you have? I would like to try one too, but as mentioned, was concerned about lift height.
I'm not sure how this old thread got revived.
I bought the subsoiler from TSC. This is the long shanked, chisel pointed, 3-point hitch attachment. On my 2305, it clears the ground by about 2-3 inches on level ground. I had to be careful transporting it, because on uneven ground, the point would would hit even with the 3-point hitch fully raised.
I did use it to ditch from the house to the tractor shed. Had to make 2-3 passes because of roots and rocks, had to use a narrow trench shovel to clear the dirt out before laying the cable in. I didn't try the cable feeder idea.
   / 2305 and subsoiler #15
4520, I am going to give it a shot in a few weeks.
Steve
   / 2305 and subsoiler #16
:D :D That's a bit bigger than my little B!
2017 CATERPILLAR 246D SKID STEER (A52705)
2017 CATERPILLAR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2011 Chevrolet Equinox SUV (A55758)
2011 Chevrolet...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
