2305 and drawbar use
   / 2305 and drawbar use #1
fdmars
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
How much can you tow w/ a 2305 and a drawbar? does any know how much weight you can put on the drawbar, and the size of the holes for putting on a ball? How well does the locking kit work and what is it's load rating?
I am looking to move a 4,500 pound boat on a tandem axel trailer around at my house, will this set up OK vs a full fledged 3pt hitch set up (costs about 3x as much) Any thoughts are welcome.
Thanks Fred
   / 2305 and drawbar use #2
That is a LOT of weight for a 2305!
   / 2305 and drawbar use #3
If you do move anything like this, I would use the drawbar to keep the weight as close as possible to the wheels. This is what the drawbar is made for. I would personally not do it unless the yard was pretty much 100% flat.
Just my 2 cents.
   / 2305 and drawbar use #4
Maybe I am confused, but The 2305 does not have a drawbar? Only a little hole in a plate mounted to the transmission?
What is the tongue weight of the trailer?
Kenny you are
Correct, I was going to buy one, and the stabilizer kit for use w/ a trailer ball.
the tongue weight would be about 500 lbs. total weight of pull around 4500 lbs. I am surprised that the tractor cannot pull it. But that is why I am part of this forum to tap into far more experience that mine.
Thanks
   / 2305 and drawbar use #6
I would think the 2305 would pull it on the level, stopping would be the real challenge.
   / 2305 and drawbar use #7
It would outweigh your tractor 3 to 1. That little Deere is a nice machine, but that is asking a bit much. With my similar sized Kubota, I find 2500 lbs to be its max. Even that is almost 2 to 1, so I go very slow on level ground and not very far. :D
When pulling the fishing boat or pop up camper from place to place around here, it barely knows they are behind it. Approximately 1600 lbs. by way of comparison.
   / 2305 and drawbar use #8
Kenny you are
Thanks
OK, I understand now...Your machine will pull it just fine-you only need to worry about stopping it. The previous warnings of hills should be heeded. Use low gear and 4WD to help control it. Also, be aware there is no downpressure on the 3PH, so the arms can lift up if the tongue weight becomes negative-that could lead to a very dangerous situation.
Do you have a iMatch or other quick hitch?
How often do you plan on moving this or other trailers?
I would not be doing it very often, but a fairly steep paved driveway is involved, your comment on negative weight and stopping is hittting home, so at this point I am thinking it might be a good idea to find an different method.
to all thanks for your thoughts.
   / 2305 and drawbar use #10
Yeah, re-thinking twice is better in deep kimchi once. 4500+ lbs is the very far end of what I would on the back of a subcut. That's just me. With a hill in the equation? I'm left just head scratching.
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
2014 TROXELL 130BBL VACUUM TRAILER (A50854)
2014 TROXELL...
