2300' water line install
   / 2300' water line install #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Finally installed 2300 foot water line to our barndominium. Its been such a wet spring the ground was finally dry enough. Not a moment to spare as we moved in the next day :)
   / 2300' water line install #3
Getting water is often a real chore, huh ?
Ours is a spring 1000' up the mountain (horizontally...about 60' vertical rise). Had to build a spring box, then put in collection tank, then we tried to Ditch Witch the line.....way too many rocks (fortunately, the would come out...not solid) so I bought an ancient International backhoe, and dug the ditch. We ran glue together 20' bell end joints of 1" PVC and slid 100' at a time inside 4" black corregated to hopefully keep rocks from damaging the PVC. This was in 1983...and it's held ever since...so maybe that was a good idea.
enhance
Great job, but am wondering what the couple small leaks were and the pressure involved. Thanks for the video.
Pressure at the meter was 60 psi
Two small leaks were in the two big T's in the NPT threads. I should have used more teflon tape or pipe dope instead.
   / 2300' water line install #5
Great thread. We had a **** of a time on our 1500 ft run. Ended up doing 2" bell end. If I had it to do over again I would go with HDPE.
   / 2300' water line install #6
My spring is about 30 feet lower than the house and around 100 feet away. I ran the inch and a half plastic water line inside 4" heavy wall plastic pipe. That was 38 years ago and it's still going strong.
   / 2300' water line install #7
Did you price and or study the feasibility of using HDPE pipe? Buying that much the supply house should let you borrow the fusion tool so you wouldn't have to have splices. Wouldn't have hurt to have sleeved the run under your driveway. Thanks for the video.
   / 2300' water line install #9
Looks like one of the benefits of being in Texas is not much depth of bury required. Looks like about 15", so it make for fast digging.
The ground never freezes. Just needs to be deep enough to avoid damage. I put it in 2 feet deep where it crossed my hay pasture just to make sure I don't some day tear it up with a chisel plow.
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
Jumper Cables (A53316)
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
1481 (A55758)
1481 (A55758)
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
Giyi 59" vibrating bucket (A53316)
Giyi 59" vibrating...
