2300' water line install
   / 2300' water line install #11
Cool video. That's a lot of pipe!
Did you price and or study the feasibility of using HDPE pipe? Buying that much the supply house should let you borrow the fusion tool so you wouldn't have to have splices. Wouldn't have hurt to have sleeved the run under your driveway. Thanks for the video.
Once I figured out the supply house was helpful, I just went with whatever they recommended.
Yeah, I probably should have put the pipe under the road in some 3 steel pipe I have laying around. I値l see if it ever becomes an issue.
   / 2300' water line install #13
One of my daughters and SIL are developing property they bought.. last year, they brought in power and got the well put in.. Foundation went in recently so they are on the way..
The well has 60+ gallons per minute using air test (that's the good news), but it is 720' deep. They are way over budget on well and will be stretched on putting pump in. I can't say they will be over budget on pump since they redid the budget once the well was drilled. They might haul water for a year, they highest priority is getting the house up before weather stops in the fall.
The local water district would connect them for $80k, which was not feasible, but they will end up over half that..
   / 2300' water line install #14
Geez - and I am complaining that our county increased water taps from $800 to $1800. Sure beats $40k!!!
   / 2300' water line install #15
Nice job -- I'll remember this the next time I grumble about trenching 100-200'.
About those leaks -- through many plumbing projects I have come to hate threaded fittings. They are just not as bullet proof as I'd like. A problem I find in recent years is that the threads aren't cut perfectly sometimes and/or they are not protected well in shipping/handling. It doesn't take but a ding or knick, or slight deformation to contribute to a leak. I avoid threaded connections as much as possible.
2021 Kenworth T800 Tri-Axle Heavy Haul Truck, VIN # 1XKDP4EXXMR429579 (A54865)
2021 Kenworth T800...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A56129)
2013 KENWORTH T680...
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A51406)
(INOP) 2017 FORD...
Parker 2600 Gravity Wagon (A50775)
Parker 2600...
Atlas Tire Changer (A50775)
Atlas Tire Changer...
