230 power steering hydraulic fluid
   / 230 power steering hydraulic fluid #1
ctny yankee
Massey ferguson 230
Was topping up steering fluid on new to me 230 (Perkins diesel) according to directions, and when I turned the wheels light brown milky fluid showed up in reservoir filler port. Assume this means water got in there? Is there a way to drain the fluid, or do I need to remove the reservoir and drain? Neither repair manual nor operator's manual say anything about this. If so, is this difficult? Any ideas on where the water got in, if that is the issue?
Any help appreciated.
   / 230 power steering hydraulic fluid #2
Yes, I would pull the reservoir and drain it. Also drain the lines to the cylinder to make sure all water is out. Once you fill it back up you may have to work it back and forth to get all the air out.
Jeremy
Jeremy
thanks. Will do.
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
(7) STABILIZER JACKS (A51248)
(7) STABILIZER...
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2022 Chevrolet...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
