Oil & Fuel 225e boggs down
/ 225e boggs down #1
buggyboy
ls 225e
changed all filters and fluids fuel pump was bad put new pump on stared it up now when I drive it when I start to get under load the rpms drop off bad. I was in medium 2500 rpm rhen drops down to under 1500rpm any ideas???
/ 225e boggs down #2
Fuel lift pump or injector pump changed? Is the throttle linkage is set correctly and getting full throttle? Check for partially blocked lines
/ 225e boggs down #3
Check for a clogged vet in the fuel cap. Try loosening it and running the tractor as you were doing. Check for loose fuel hoses sucking air. Check to see if there is dirt / debris in the tank. Depending on the age of the tractor (in 2020 LS started to use an electronic throttle control), it could be that controller if present.
I am assuming it is no longer under the bumper to bumper warranty..... I think the fuel delivery system is under the drive train / emissions warranty.
Good luck finding the problem!
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
20ft 4-Door Shipping Container with Shelving (A61572)
20ft 4-Door...
Ford F800 (A63689)
Ford F800 (A63689)
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
more info coming soon! (A61569)
more info coming...
