2210
Hambone
Platinum Member
Southeast Kentucky
JD3032
Anyone ever turn wheels around to the wide position?
If so, any problems using MMM when doing this?
Steve, are you talking front, back, both? Looks like on my 2210 if I reverse the fronts I would gain about 2" overall, but if I reverse the backs I would actually lose about 4" overall (also may be clearance problem with the 3 point arms and other parts) if I am looking at it correctly. In any case I do not see a problem with the MMM.
Ken /forums/images/graemlins/smile.gif
/ 2210
I didn't even look at the rear, just looked like the front would be a little wider. Wider is better!!
You should put the left tire on the right side and right on the left side, so that the tread pattern isn't reversed. The only thing is that the valve stems are then on the inside, which isn't a problem. Extra width should give additional clearance for the MMM and extra stability for an FEL if mounted.
I'd like to switch the fronts left to right and right to left on my 4410 for loader stability. My only reservation is added stress on the steering components and fwd.
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
John Deere 4044M (A60462)
John Deere 4044M...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 3715...
2015 CATERPILLAR 299D2 SKID STEER (A64279)
2015 CATERPILLAR...
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
