2210 seat replacement
/ 2210 seat replacement #1
wiscbill
I give up, this is the best I could do to attach photo's.
Earlier this spring E-Bay had John Deere discontinued seats for sale that were used on X series Garden tractors for the
European Market. I bought one and installed it on my 2210.
These seats look like the seats used on the larger compacts
with the exception that the weight adjust is in metric. I had to
take off the rubber accordion skirt on the bottom which
rubbed on the 3 point lever, drilled two new holes in the suspension of the seat and two holes on the tractor mount.
Seat suspension is adjustable spring and gas shock. I had to
tighten the seat height adjustment down as much as possible
so the seat didn't stand so tall when it was empty, but still
sits about 4 inches higher than the original, about the same
as the original when you sit on it and compress the suspension. I took the ROP off because of low branches, don't
have a FEL just a snowblower and 62 MMM.
[image]
http://www.tractorbynet.com/photos
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
CAT 621B Final Drive (A68134)
CAT 621B Final...
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2001 MACK VISION DUMP TRUCK (INOPERABLE) (A67714)
2001 MACK VISION...
2022 INTERNATIONAL LT625 DAYCAB (A67714)
2022 INTERNATIONAL...
