2210 question
/ 2210 question #1
JimD
S.E. Michigan
2210 JD
I need some help from my fellow 2210 owners. Can anyone tell me how many seconds it takes for you to lift the FEL bucket from level ground to full up position? I think mine is running a little slow, from when it was delivered. /forums/images/graemlins/confused.gif
/ 2210 question #2
I have a 2210. The lift speed is real sensitive to RPMS's anything less than 3000 will slow it right down. Thing almost seems to creep at slow idle.
/ 2210 question
I'm not sure about the RPM's I will try that tonight. But, the manual for the 210 loader stated that the lift speed should be 3.8 seconds. I'm about twice that at idle speed... I am really interested in what someone else gets when they time it..
/ 2210 question
I though I should post the cause of my loader problem. Just incase anyone else comes up with the same symptoms.
The reason my loader was moving so slow is because there was a small chunk of rubber hose caught in the male coupling. I removed the chunk of rubber and presto loader meets the cycle time 3.8 sec..
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
John Deere 950 Tractor (A65579)
John Deere 950...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
