2210 question
/ 2210 question #1
JimD
Bronze Member
S.E. Michigan
2210 JD
I need some help from my fellow 2210 owners. Can anyone tell me how many seconds it takes for you to lift the FEL bucket from level ground to full up position? I think mine is running a little slow, from when it was delivered. /forums/images/graemlins/confused.gif
/ 2210 question #2
I have a 2210. The lift speed is real sensitive to RPMS's anything less than 3000 will slow it right down. Thing almost seems to creep at slow idle.
/ 2210 question
I'm not sure about the RPM's I will try that tonight. But, the manual for the 210 loader stated that the lift speed should be 3.8 seconds. I'm about twice that at idle speed... I am really interested in what someone else gets when they time it..
/ 2210 question
I though I should post the cause of my loader problem. Just incase anyone else comes up with the same symptoms.
The reason my loader was moving so slow is because there was a small chunk of rubber hose caught in the male coupling. I removed the chunk of rubber and presto loader meets the cycle time 3.8 sec..
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
90in. Work Bench (A65640)
90in. Work Bench...
SRECO Flexible Sewer Cleaning System (A65579)
SRECO Flexible...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
