2210 Leak Down Rate
/ 2210 Leak Down Rate #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am trying to figure out if I have a problem or not. How long should my 3 point and my front end loader stay up after I turn the tractor off. Is that 6 hours, 12 hours, ? The loader does not have the bucket on it and the 3 point only has the i-match setup on it. When I first got the tractor I thought I had a minor hydraulic leak. I am trying to figure out if I have a problem or not. Comments?
D.
/ 2210 Leak Down Rate #2
I have never timed my leak down. I just know it happens overnight. I have noticed that if I shut my tractor off with the box blade in full "up" position, and then start it and hour or so later, that the hydraulics snap it back to the full up positions again. Maybe it's and inch drop, or so.
I was always taught to drop my loader and implements when shutting my tractor down because it's going to end up there over time anyway.
/ 2210 Leak Down Rate #4
Prosperity--that's kind of what I was trying to say--for safety's sake. Occasionally, I'll hop off to dig something up--real qucikly--and I'll still be digging an hour, or so later. You know the drill /forums/images/graemlins/frown.gif
I usually drop them, I just was wondering if I have a problem or not. I think everything is OK.
D.
/ 2210 Leak Down Rate #6
Ok - safety aspects aside....
I work with large loaders, graders, backhoes, etc on a daily basis. All hydraulics, even new, will leak down over a certain time without the pump running. It's just plain old gravity taking over.
Nothing to worry about - absolutely normal.
/ 2210 Leak Down Rate #7
I actually took my 2210 to the dealer for exactly this problem (along with a few other things). It was still under warranty (only 25 hours!) so I asked them to check it out. They said mine was within spec. I think they said something like 2" per hour is "spec" on the loader. I don't remember what they said about the 3 point.
Dave
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2023 WEILER S350 SKIDDER (A65056)
2023 WEILER S350...
7ft Fork Extensions (A66734)
7ft Fork...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
