2210 Leak Down Rate
/ 2210 Leak Down Rate #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am trying to figure out if I have a problem or not. How long should my 3 point and my front end loader stay up after I turn the tractor off. Is that 6 hours, 12 hours, ? The loader does not have the bucket on it and the 3 point only has the i-match setup on it. When I first got the tractor I thought I had a minor hydraulic leak. I am trying to figure out if I have a problem or not. Comments?
D.
/ 2210 Leak Down Rate #2
I have never timed my leak down. I just know it happens overnight. I have noticed that if I shut my tractor off with the box blade in full "up" position, and then start it and hour or so later, that the hydraulics snap it back to the full up positions again. Maybe it's and inch drop, or so.
I was always taught to drop my loader and implements when shutting my tractor down because it's going to end up there over time anyway.
/ 2210 Leak Down Rate #4
Prosperity--that's kind of what I was trying to say--for safety's sake. Occasionally, I'll hop off to dig something up--real qucikly--and I'll still be digging an hour, or so later. You know the drill /forums/images/graemlins/frown.gif
I usually drop them, I just was wondering if I have a problem or not. I think everything is OK.
D.
/ 2210 Leak Down Rate #6
Ok - safety aspects aside....
I work with large loaders, graders, backhoes, etc on a daily basis. All hydraulics, even new, will leak down over a certain time without the pump running. It's just plain old gravity taking over.
Nothing to worry about - absolutely normal.
/ 2210 Leak Down Rate #7
I actually took my 2210 to the dealer for exactly this problem (along with a few other things). It was still under warranty (only 25 hours!) so I asked them to check it out. They said mine was within spec. I think they said something like 2" per hour is "spec" on the loader. I don't remember what they said about the 3 point.
Dave
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-250...
2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
BOBCAT 751 SKID STEER (A65053)
BOBCAT 751 SKID...
PORTA POTTY (A67714)
2008 FORD F-350 UTILITY BODY (A66091)
2008 FORD F-350...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
