Tractor Sizing 2210 front lug wrench size
   / 2210 front lug wrench size #1
passgas55
I know this has been answered before and I thought I saved the info but I guess I did not. I did a search and came up empty handed. So what is the size wrench for the front lugs for a 2 wheel drive 2210? I promise this time to save it in my tractor file. Thanks.......
If the tractor was not over 70 miles away I would not be asking this question. I guess I will bring a big cresent wrench with me. Maybe I should have said bolts instead of lugs.:)
   / 2210 front lug wrench size #3
They are a 14mm bolt but I have seen them with a couple of different head sizes. It is normally a 19mm I think but I would take a few sizes up & down from there to be sure.
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / 2210 front lug wrench size #4
The head size does vary depending on the bolt supplier. 19mm is most common. Invest $30 in a Harbor Freight socket set ([FONT=arial, sans-serif]ITEM 45467-1VGA) and cover 80% of your needs on that tractor for app. $35.00 One set of wrenches which should include 8, 10, 13, 17, 19mm will cover 90% of your wrenching needs.
[/FONT]
Just got back and I was able to use a 7/8 inch wrench which was a little loose. I moved my tractor from an old milking barn to a lean two. I wanted to remove my wheel from the tractor. All done now, the meth heads have to work a little to steal the tractor.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
