2210 cooling system
/ 2210 cooling system #1
keen
Here goes.. Engine runs fine, but is starting to run hot. No apparent leaks in cooling system, belt seems tight, cleaned debris screen on front of radiator. Do the hydraulics cool thru the engine?? Any input is appreciated...
Kirk
/ 2210 cooling system #2
"cleaned debris screen on front of radiator"
What about the radiator, inside and out?
Inside and outside of radiator cleaned. Still the same problem..
/ 2210 cooling system #4
Are you talking about your JD2210?
If so, yes I know it is a Yanmar, you would probably get more responses on JD forum.
/ 2210 cooling system #5
How was the radiator cleaned, (is it clean), and was it flow tested?
