2210 Cab on a 2320
   / 2210 Cab on a 2320 #12
chevy said:
Last spring I traded my 2210 for a 2320. I had an Original Tractor soft sided cab for the 2210. Late in the summer I discovered that Original did not make a cab for the 2320. I decided to try & adapt the 2210 cab to the 2320. They are calling for several inches of snow tonight & tomarrow. So after lunch I decided to install the cab. It went better than I expected & turn out very well.
Looks very good. i have a question i hear that aftermarket cabs are pretty loud inside and they occassionally have an issue witrh fumes. Are you experiencing any of those issues?
jsb2b said:
Looks like it will be "toasty" this winter!! Good job.
Noticed your 62D draft arms are down.... Don't let them get bent$$$$:eek:
I had not locked them up when the picture was taken. Just before I started on the cab install I removed the deck & serviced it.
It is very loud inside the cab.
I have Peltor hearing protectors that I wear anytime I use the tractor. Cab on or not.
Fumes have never been an issue.
   / 2210 Cab on a 2320 #15
Chevy,
I also have a 2320 and have been looking for a cab. I have been bothering Original Cab Co. about this for 6 months and I received an email from the company recently with a picture of their new cab for the 2320. I noticed in your pics that you have the bar up and was wondering if you could still mount the cab securely with the ROPS down? I am trying to fit it into a garage with 7ft clearance. Obviously I could not have the ROPS up. I was thinking about modifying it some how to attach it with the bar down.
I also have to fold the roll bar down to get in my buildings. To support the cab, I made a small small wood frame that I mounted to the lower roll bar frame.
2001 Volvo A25C 6x6 Haul Truck (RIDE AND DRIVE) (A50775)
2001 Volvo A25C...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2017 Ford F-150...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
