2210 Cab choices?
/ 2210 Cab choices? #1
djsch
Watertown, SD, USA
JD 2210
I just finished blowing snow for 2 driveways in a 30 MPH wind. I love the blower but I would like more protection from the wind and snow. I know that Kozy Cab and Curtis both make units for the 2210. The softside Curtis is $1,600 and I can't find a price on the Kozy. I have a few questions before I spring for one of these.
1) Does anyone know of any other sources for cabs for a 2210?
2) Does anyone know the price of a Kozy Cab softside unit?
3) Are there any discount sources for cabs on the I-net? (So far my searches have come up empty.)
4) Who makes the best cab - Kozy, Curtis, or ???
5) What should I watch out for when shopping for cabs?
Thanks for any ifo you can share.
Dave
/ 2210 Cab choices? #2
djsch, if you are looking for a less expensive cab, look at the original tractor cab company at Original Tractor Cab . i just got mine a few weeks ago and it only took 2 hours to install. it's not a top of the line cab, but it does protect you from the elements.
rsthom
/ 2210 Cab choices?
Thanks for the tip! I had looked there but didn't look deep enough. It looks like just what I'm looking for. Did you buy it direct or is there a discount outlet somewhere?
Dave
/ 2210 Cab choices? #4
I put a Curtis softside on my 2210. I shopped and decided, yeah..it's pricey..but very solid. Plus it included the electric windshield wiper (a necessity) and a very heavy glass windshield that opens for ventilation. I think the shipping weight was around 300lbs.
I have a soft cab for a Craftsman tractor that I gave $400 for 5 years ago and it is flimsy. Clamp-on tube frame and soft curtains all around. The Curtis is 5 times that setup.
The doors pop off the hinges easily and the rear curtain is velcro'd. Handy for operating the sander lever and having just roof/windshield cover in the summer.
Get what you pay for.
/ 2210 Cab choices? #5
Wildman1
How was that curtis cab to install? how long did it take to install any drilling? Thanks PeterT
/ 2210 Cab choices? #6
DJ,
I do not know how much you want to spend, but I used a golf cart cover for my BX, was about $125. Worked great last winter. Maybe an option until you find the one you realy want /forums/images/graemlins/grin.gif
Here is a link to my project.
link
/ 2210 Cab choices? #7
Dave, i did by the cab direct from Original Cab and they did ship ups to me at work. the cab does have a plastic top that bolts onto a frame, the rest is all vinyl that wraps around the frame and snaps together. the doors do lift off somewhat easily. the frame is all tube that bolts together and no drilling on my 790. if you want any close up pictures, let me know and i can snap a few this weekend.
Rick
/ 2210 Cab choices?
Thanks for the picture Rick. Nice looking rig! Original is supposed to be sending me pictures of the 2210 cab. If I get them I'll try to post them. Meanwhile, any pictures you would be willing to share would be appreciated. Did you have to drill holes etc to mount it? Did you get the lexan windshield or the safety glass and the wiper? Original suggested the safety glass and the wiper if I was going to run more than 30 minutes at a time. Since I do that regularly, I'm concerned. I'm wondering why the operating time makes a difference? (I've asked them the question and hope for an answer today). Do you have problems with the windshield fogging up or frosting over? Do you have any problems with material freezing to the outside?
Dave
/ 2210 Cab choices? #9
Rick - I'd also appreciate seeing a couple of closeups, especially how it attaches to the 790. Do you think the Top is substantial enough to hold two lights that are currently attached to my ROPS (see pix)?
I understand you need to buy the Safety Glass Windshield if you want to use a wiper (Lexan windshield scratches). Which windshield (and wiper) did you buy?
/ 2210 Cab choices? #10
Dave and Mountain Man, for now I just got the lexan windshield, after thinking about it, I may get the safety glass windshield and hand wiper. This is the first season I have had it and no snow yet to see if it fogs up. I have noticed when I was using it the other day moving implements around and getting ready for winter the rear lexan window would fog up a little bit from being turned around while lining up to the implement. I did notice after awhile being in the cab, it was a little warmer than outside, I wounder if the combination of the heat from the tractor and you in the cab affect fogging ? Also I don't know if the matierial will freeze to the tractor yet, if we ever get enough snow to play or work in, I will find out.
For the mounting it went pretty easy, no holes to drill for the brackets on the fenders or floorboards . I did run into one problem where the window supports mount under the hood. They said to unbolt the rear side panel mount and use a longer bolt to mount the support. That would have been ok if my rear mount were bolted on instead of welded on, but the hole was there. So I found a couple rubber well nuts and drilled the holes alittle bigger and installed the well nuts and mounted the brackets with no problems. I'll post some pics next time I'm home in the daylight, hopefully this weekend.
I will also look at the top about the light mounting also.
Rick
/ 2210 Cab choices? #11
PeterT..
No drilling. It took me about 4 hours to install minus installing the worklights, electric heater and windshield wiper. I didn't have the right sized hex head wrench for the mounting bolts (lots of them) and didn't want to drive 20 miles to get one...so I ground the edges of the heads to use a wrench. Pain. The drive would have cost about the same time as it cost me to grind the bolts.
You really need 2 people to mount the windshield (heavy) and they recommend 2 people for the roof. I did everything alone except for the windshield (they were right).
It's pretty straight forward and is solid as a rock.
/ 2210 Cab choices? #12
On the fogging issue...yes, the windshield will fog up. I've plowed 4 times in the last 7 days doing 6 driveways for a total of around 6 hours of work. Temps around 20f. I mounted my honda genset on the spreader to run a 800w interior car warmer mounted overhead at a 45 degree angle blowing on the windshield. When I had to sand I took the genset off the spreader (duh) and within 10 minutes the windshield started fogging. So, interior heat is needed. Also, the windshield wiper is a must...especially when it's windy. The snow blows onto the windshield and pretty quick I've got to run the wiper or see nothing. Electric is great but a hand operated one would do as well. I just flick the switch for a couple of seconds and turn it off again.
A cab sure beats turning into a snowman.
/ 2210 Cab choices? #13
Dave and Mountain Man, here are a fews pics i took this morning of the cab. This pic shows the mount to the rops and fenders.
/ 2210 Cab choices? #14
This shows the mount to the floorboards. The left side by the clutch pedal just slips over the the front and you tighten the bolts to pinch it tight to the floorboard.
/ 2210 Cab choices? #15
This pic shows where the windshield support mounts under the hood. This is where there was to be a bolt. Instead there was a hole that I put in a rubber well nut to attach the brace.
Also a close up of the door handle. The handle is spring loaded and just slides on the center support of the door. Not pretty, but usefull.
/ 2210 Cab choices? #16
Here I took a pic of how the plastic top mounts to the frame.
Mountain Man, these bolts run all the way through the plastic top to the outside, this may be a good support for mounting the worklights. The other pic shows how thw door opens and leaves plenty of room to enter the cab. I may try to put some foam in the top of the cab to reduce some of the noise.
Rick
/ 2210 Cab choices? #17
Rick - Thanks for taking the time for the detailed pixs. I agree the top looks just fine to mount the lights. I've ordered one from OTC (on clearance!) since they're closing out manufacturing of the cab for the pre-2002 JD 790's. Let us know if you have any luck with foam and if you need to purchase the glass windshield/wiper.
/ 2210 Cab choices? #18
Rick - Finished installation of the OTC cab & lites over the weekend. I was surprised how rigid the frame was (doesn't look like it from the pictures). Installation was straight-forward, instructions could have been a little better, but everything was there and fit well.
I've got concerns about potential scratching of the lexan windows. I'll probably end up buying the safety glass windshield. My other concern is the wind warning of 25 MPH. Here in the Rockies, it's not uncommon to have gusts of 75 MPH or more. I'll try to keep the tractor inside on very windy days.
Here a picture ready for the snow (expected today!)
Please let me know if you do purchase the windshield/wiper setup (and what you think of it) and if you find the right sound absorbing foam for the top.
/ 2210 Cab choices? #19
Here's a closeup pix of the lights. I used the same ones as on the ROPS previously ($20 at Autozone). I wired the new lites into the same circuit as aux lites (off 10A fuse #4), so they go on with the headlights. I disconnected the ROPS lites, but may turn them around (facing backwards). However I will need to work on switching the rears ones separately (no reverse switch on a JD790).
/ 2210 Cab choices? #20
Mountain Man - thanks for the pictures of the lights, I want to add something like that to the front of my cab also. I did pick up a little spot heater this weekend to try to help prevent fogging if it happens, as soon as I get it mounted I'll take a pic and post. Did you find the snowblower used or get it new?
I am trying to find a used one at a cheap price for my 790 also but they seem to be worth about the same new or used.
Rick
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2006 Chevrolet 3500 Flatbed Truck (A63116)
2006 Chevrolet...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63118)
Snap-On Gold Medal...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
