2210 bucket won't curl at high rpm
   / 2210 bucket won't curl at high rpm #1
bboard
I was hoping for help on this one?
   / 2210 bucket won't curl at high rpm #2
Welcome to TBN. :)
   / 2210 bucket won't curl at high rpm #3
Can you describe the problem in a little more detail? Several manufacturers have a model "2210"...What exactly do you have?
sorry, It is a 1070 john deere about 20 years old. At low rpm all the bucket functions work fine, when you bring the rpm up the curl function goes into a relief and all other fuctions work fine. If you bring the control lever in slow it will start to curl untill you put the lever into full curl position and then it will go into relief again. The hydrolic control body has been replaced.......Looking for the next best way to spend some more money..
   / 2210 bucket won't curl at high rpm #5
Who replaced the control valve?? and was it an OEM valve, or did you just pick one at a hydraulic place online??
It should NOT be going into relief just by reving the engine. It makes me want to say that it is either installed incorrectly or is the wrong valve. It should be open center.
Also, check your rear remots if you have them. You may have accidently bumped the lever.
The valve was replaced with one from John Deere, It will go into relief when you try to curl the bucket at a high rpm. (anything above 1000 rpm) If you bring the rpm up without any control valves being moved it is fine, does not go into relief. Both new and old valve act the same.
   / 2210 bucket won't curl at high rpm #7
:welcome:
I'd suggest you take the thread to the Deere boards and post the question. In this "New Member Introductions" board, you may be missing some good information.
I wish that more info was presented to new members so their questions wouldn't get lost in this Board. :confused3:
Thanks, Not a easy forum to learn.
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
HURRICANE 40' CONTAINER (A51248)
HURRICANE 40'...
