2210/62C noise level / RPM question
   / 2210/62C noise level / RPM question #1
Anonymous Poster
Epic Contributor
Over the weekend I finally got a chance to mow with my 2210 and 62C. This was my first time mowing with this tractor/deck and I was concerned about the noise level as my deck doesn't have the isolation kit. I haven't done anything about this yet, so was concerned and curious!
What I found was that the deck stays very quiet up to the "PTO RPM" setting. If I pushed the throttle/RPM's any higher, the deck made a high-pitched whine reminisant of a
supercharger or non-synchronized reverse gear on an old car - even 50 more RPM's would cause this.
So...is this intentional to tell you to throttle back, or is this the
dreaded 62C sound I have read so much about? The difference in noise level is incredible.
I would appreciate any input.
Fred G
I have noticed the noise when I really crank up my RPM's. The thing I have noticed though, I have been cutting tall grass because I can't get into the yard with rain every other day. I have been cutting at around 2200 rpm and it doesn't miss a blade. It just doesn't throw it as far.
   / 2210/62C noise level / RPM question #3
When I first mowed with the 2210/62c, I noticed the same thing. Really whined - especially through the ROPS. When I was at my dealer the following week, I had them order me the isolation kit. While there, I was talking with the mechanic some. He said that I shouldn't put the kit on. He said that with the kit, when the mower gets under some load, the gear box with want to torque (twist) because of the rubber bushings. This will prematurely wear the mower belt. He said he's had some in the shop already that needed the belt replaced. So, I still have the kit waiting. In the meantime, I've mowed about 6 hours off and on. It seems that the noise is getting better (less). According to the Deere DTAC sheet, the noise will lessen when the bearings and sheaves break in. Maybe its just me getting used to the sound, or maybe it really is getting better.
So, I'm going to let it be for now. I have the isolation kit if I ever get the notion to try it. I do believe it is getting better with time. Not nearly as loud as when I first fired that mower up.
   / 2210/62C noise level / RPM question #4
<font color="green">Can someone tell me what is included in the 2210/62C isolation kit and its cost? This is the first I have heard of the kit.
Thanks,
Mike </font>
It's basically some longer bolts and (rubber?) washers that are used to isolate metal-to-metal contact of the gearbox on top of the mower deck. I don't have the part # at home, it's at work, if I remember I'll post tomorrow. I also have the price at work I will post that too. This kit is also for the 62C on the X series.
Guys,
Thanks for the info, glad it's not my imagination. I will live with it for now and see if it improves after 10 hours of mowing.
Sounds absolutely wicked at full throttle. My son thinks it's cool, my wife is not impressed.
Sure cuts the grass at the high RPM's, too.
Fred G
   / 2210/62C noise level / RPM question #7
Here's the Deere DTAC solution sheet for the 62C noise problem. Although it only mentions the (X) series tractor, my dealer got a kit for my 2210/62C without question. If you wanted the cost you could go to deere.parts.com and enter the part number.
26 February 2003
> > DTAC Solution: 55362
> > MOWER GEARBOX SEEMS NOISY
> > 62C Mower Decks on X400 and X500 Series Tractors
> > Complaint or Symptom :
> > Mower and/or gearbox seems noisy, especially if compared to
> > old 400 series tractors and mowers.
> > Situation:
> > ¥ There is no function problem. New tractors and mower decks
> > will sound different than previous models.
> > ¥ Customer may be comparing to previous 400 series tractors.
> > Tractor, mower decks and gearbox were completely different.
> > Solution:
> > ¥ Try to evaluate potential noise issues outside in mowing
> > conditions only.
> > ¥ Do NOT judge overall sound or noise level inside shop or in
> > parking lot against or near a building.
> > ¥ If one unit seems totally unacceptable when compared to
> > another X-Series Tractor with the same size mower, order and
> > install Noise Reduction Kit (AM¥ 33090). Kit includes
installation
> > instructions.
> > Approximate Installation Time: 45 Minutes
> > Additional Information:
> > ¥ As of 9 December 2002, all 62C decks have gearboxes
> > installed with isolated mounting.
> > ¥ Each 62C mower deck and tractor combination is likely to
> > sound different. Not all decks will require the isolation kit.
> > ¥ Kit will also fit 48C and 54C mower decks, although very few
> > complaints have been reported. These decks will NOT have the
> > isolation kit factory installed.
> > ¥ Actual overall sound level (noise) is the same between the
> > X-Series and the existing 400 series. However, the pitch of the
> > sound may be different.
> > ¥ New gearbox is of different design than on the old 400 decks
> > and has proven to be significantly more durable. Noise will be
> > reduced as tractor, mower, belts, sheaves, idlers, and gearbox
> > have time to break in.
> > Parts:
> > Kit (1) AM 133090 Noise Reduction
That's the part no my dealer gave me, AM133090. Parts guy said the list price was $49.02
   / 2210/62C noise level / RPM question #9
I need to take a look at mine. I do not have the same loud noise that you guy's are mentioning here.
Decks built from around Jan 2003 on already have the isolation kit installed....how long have you had your 2210/62C?
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
