2210/62C noise level / RPM question
   / 2210/62C noise level / RPM question #11
About a month and a half... So i can assume that its there.
   / 2210/62C noise level / RPM question #12
<font color="green">Checked my 62C deck and I did not see any isolation components. My deck must have been shipped before the change.
When I engage the mid-PTO and the blades start turning it sounds like an airplane is taking off in my field.
Mike</font>
You described the sound well.
What stikes me as odd, I also have a used 403 4ft rotary mower, and it is almost silent compared to the 62C. All you hear is grass being cut. With the 62C you really can't hear the grass at all!!!
I actually find the noise kinda cool sounding. /forums/images/graemlins/grin.gif
Reminds me a little of the batmobile from the older series.
   / 2210/62C noise level / RPM question #15
So - my question now is -
Has anyone who has the isolation kit on their deck had any problems with the belt?
I usually try to follow my mechanics advice. He says "don't put it on as it will chew the belt up".
I would like to turn down the noise though.
   / 2210/62C noise level / RPM question #16
Rainy day today, so I decided to put on the isolation kit.
Real easy to install - about 1/2 hour.
I didn't do any mowing with it afterward, but took it outside and fired it up. As I said before, mine wasn't real bad, but quite noticeable. Ran it up to PTO speed, and I could actually hear the hum of the mower deck which I couldn't before. I still hear a little bit through the ROPS, but not nearly as bad. Of course the real test will be with it under load, but so far it cut the noise in half for me.
Like Fred_G says - I hope to be able to hear the grass being cut now!
2011 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A57024)
2011 MACK Tender...
202474 (A54757)
202474 (A54757)
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2017 BX2680 Sub Compact Utility Tractor (A57024)
2017 BX2680 Sub...
