2186 won't start
/ 2186 won't start #1
Ingo
Hillsborough, NC
Cub 2186
2186 won\'t start
My 2186 with 33 hrs on it just stopped while mowing yesterday. Turned the key and got nothing. I found out about the wiring issues here and sure enough, the headlight wiring had melted and shorted on the exhaust. Took care of that and replaced the fuse this morning. Now I get current (headlights come on), but still no action on the starter. I'm guessing that one of the cut-off switches got messed up, but I'm not sure how to test them or where to start. It's still under warranty so I'll call the dealer tomorrow--hopefully he'll pick it w/o charge or I'll have to wait until next weekend to get it over to him. In the meantime, the grass grows....
I guess the moral is to keep up with TBN BEFORE you have a problem!
/ 2186 won't start #2
Re: 2186 won\'t start
There are multiple fuses. Check them all. If it looks good, measure it with an ohmmeter or swap it with a known good one. Usually only one fuse blows in a string, but if the current surge was large enough it may have blown others.
/ 2186 won't start
Yeh, I replaced both fuses even though 1 still tested good. Unless there's hidden ones not shown in the manual...
/ 2186 won't start #4
You say it stopped while mowing and will not start now..Did you turn off or disengage the mower?
/forums/images/graemlins/confused.gif
/ 2186 won't start
Well I went to look at things again and while wiggling the PTO switch a wire popped out! Now that's a coincidence! The blade in the switch came right out with female connector. So I pushed it back in and it started right up. I've temporarily taped it in and finished my mowing for the weekend. Will pull the switch out and see if it's fixable or not.
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
2012 CHEVROLET SILVERADO 1500 (A67714)
2012 CHEVROLET...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2011 FORD F-250 SUPER DUTY (INOPERABLE) (A67714)
2011 FORD F-250...
