2155 TRANSMISSION FLUID?
/ 2155 TRANSMISSION FLUID? #1
ss76
I got stuck in the mud and had to wash everything. I didnt realize the dipstick was out of the tranny. Im not really sure if i got water in the case or not. I had to run it to get it on the trailer but it wasnt milky after i loaded it. Do i need to buy the hydro fluid for a cub or does it use regular hydro fluid?:eek:
Thanks.
Well, just unloaded it and put it the barn. Its milky.ERRRRRR!
/ 2155 TRANSMISSION FLUID? #2
Use Shell Rotella-T 15w40 in place of the ~$10/qt drive system fluid plus.
Joel
Thnks Joel. I am a firm believer in synthetics. Should i use a synthetic in this case? All of the new diesel oils have a high zinc formulation (wich i use to break in our race motors). Since a hydaulic fluid is a low viscosity, would a 5w40 be better than the 15w40? Thanks for your help. Dwight.:eek:
/ 2155 TRANSMISSION FLUID? #4
..Since a hydaulic fluid is a low viscosity, would a 5w40 be better than the 15w40? Thanks for your help. Dwight.:eek:
These transaxles spec motor oil, not hydraulic oil. 15w40 or 5w40 are both a 40wt at normal operating temps. The 5w40 will flow easier in extreme cold. 5w40 is an excellent choice for the engine and transaxle on these. It's just more expensive (and a synthetic blend) than 15w40. I run Shell Rotella-T 5w40 in the Kohler Command 20 in my 2544 and 15w40 in the trans.
Joel
15ft. Hay Rack (A65640)
15ft. Hay Rack...
Pat's QH and hydraulic top-link.
Pat's QH and...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
Iranch IRMT Mobile Restroom (A64127)
Iranch IRMT Mobile...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
