2155 Rear axel trouble?
/ 2155 Rear axel trouble? #1
plmojn
N.E OHIO
I just bought this tractor last summer, had it out yesterday in the snow and noticed only one tire is driving, if I put the differential in then both drive. The brake peddal on the left wich is the one thats driving is up good when pushed, the pedal on the right goes down about 3 inches, they had been locked together sence I bought it. Anyone know what would be wrong? thanks for any advice
/ 2155 Rear axel trouble? #2
Sounds like it's perfectly normal and working fine. Your only going to get one wheel to drive unless the diff lock is pressed. As far as the brake, you can adjust one side up a little. I doubt that you will get them exactly the same though. Nothing sounds like you have a problem.
Sincerely, Dirt
Dirt, Did not have much time last night to fool with it, went out today and your right I guess you have to lock the differential. New to me, my old ford and allis dont work quite like that. I ordered a manual. thanks
/ 2155 Rear axel trouble? #4
I agree with DW, sounds normal except possible needing a brake adjustment.
/ 2155 Rear axel trouble? #5
Also in 4 wheel drive you only have one rear and one front pulling or with the diff lock in. Both rears and one front.
Sincerely, Dirt
/ 2155 Rear axel trouble? #6
You might have a little air in the brakes also. Try bleeding them to see if that makes the pedals more even. The bleed screws are located on the top of the rear axle housings.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2007 CHEVROLET SILVERADO 1500(INOPERABLE) (A67714)
2007 CHEVROLET...
TWO PALLETS OF HOSES AND EXTENSION CORDS/LIGHTS (A67714)
TWO PALLETS OF...
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
