2155 no spark!
   / 2155 no spark! #11
I don't think what you did is telling you much. The wire from the magneto is just for grounding it out to stop the engine. When its not connected to anything, crank the engine and if the magneto is good then you should have spark at the spark plug. If you have no spark then the magneto is bad or the gap between it and the flywheel is wrong.
   / 2155 no spark!
K no spark I gaped it with a business card but will go do it again. Also I hooked the test lite to the positive and touched magneto also the ignition module and the test lite lit up like something is grounding out the magneto maybe I am wrong I am just trying different thing but no spark with the wire unhooked though thank for giving me advise this thing is driving me crazy lol!
   / 2155 no spark!
Well I thought about it and the magneto is part of the motor so I was wrong I think since the motor is grounded.
   / 2155 no spark! #14
The gap between the magneto/ignition module and the flywheel should be .008-.012" which about the thickness of three sheets of paper.
When I say the wire grounds out the magneto I mean it grounds the internal coils that generate the spark.
   / 2155 no spark!
i just ordered i used flywheel off ebay $20 better than $ 200 so i will rip er apart c what happens.
   / 2155 no spark!
well i have replaced the ignition module checked all switches also unpluged the ground wire to the module still no spark it ran perfect i shut it off week later no spark i hate being a parts changer but i dont knw what else it could be.
   / 2155 no spark!
no points i also have multi meter i was testing with to idn when i figure it out i let everyone or lght it on fire lol!
   / 2155 no spark!
Okay guys just took flywheel of seems my rear seal is leaking and inside the flywheel was cake with dirt and oil going to clean and see what happens!
   / 2155 no spark!
well i fixed the problom and learned a lesson i had the new coil on backwards lol never paided attention to the arrow on the coil!
Ratchet Straps (A55852)
Ratchet Straps...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
UNUSED RAYTREE REDM32 32" HYD EXCAVATOR MULCHER (A57193)
UNUSED RAYTREE...
PALLET OF BAR LOCKS (A57192)
PALLET OF BAR...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
