Oil & Fuel 2155 Low power...
/ 2155 Low power... #1
rogmcc
Prospect
JD 2155
Looking for some thoughts from you all before I pay hundreds of $$ to have this thing hauled into the dealer.
A couple of months ago I lost power while bush hogging. Felt like a fuel issue - temps were ok. Not smoking. I dumped some diesel conditioner in it and parked it. Next time I ran it (2 months later) it was fine and I mowed about 20 acres at normal power. Last night - 1 month later, fired it up and it would barely get to mowing RPM, even in neutral. Very low power - again, no smoking. I changed fuel filter. - Oil and coolant are fine. About 3900 hours on the tractor.
Thoughts?
/ 2155 Low power... #4
How old is the fuel. With the months between use the fuel could have gone bad. Also old fuel will grow alge. You could have a restricted valve at the bottom of the tank or any where. I would pull line loose from tank to filter at the filter and make sure you have good flow. Then check line filter to pump. Then some new fuel and conditioner and run it some. Good Luck.
/ 2155 Low power...
Thanks - Fuel isn't too old, and the filter is clear glass so I can see that it is staying full. I will pull that line and check it though, as this really does seem like a fuel issue.
/ 2155 Low power...
I cleaned it out the last time this happened. It stays pretty clean, but I will pull it out and at least eliminate it as a possibility.
/ 2155 Low power... #7
I'd suggest checking the lift pump to see if it's pumping good.
Used 20' Container (A62679)
Used 20' Container...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
