2155 leak
/ 2155 leak #1
red44
Hi folks. Newbie here. I have a minor issue that rears it's head every winter and I'm wondering if there's a fix. On our 2155 there is a shaft that runs through the "body", it is what the two arms of the 3 pt hitch attaches to. The shaft has seals at the body, but every winter these seals leak out most of the hydralic fluid. I've replaced these seals a few times, but I guess they are temp sensitive? They don't leak a drop spring thru fall. Any better options? Thanks.
/ 2155 leak #2
Welcome to TBN:D
I helped friend fix this very same problem on his machine (unsure of the model number). I only have two thoughts:
1-You are damaging the seals when you are installing them, it's a tight fit to get them in there. I boiled them in water to soften them, then folded them into a W shape to insert them.
2-The shaft is slightly worn where the seal contacts-you might need to mic the shaft when it's removed.
/ 2155 leak #3
I agree with kennyd. The shaft may be worn and also the bushings that the seals go into may be worn. How long since you replaced the seals? There was a batch of these that did leak in cold weather a few years ago. The new seals are now blue in color and made from a different material. They are much better than the old amber colored ones.
/ 2155 leak
Thanks. I have'nt replaced them in a couple-3 years. At least now I have a clue. :thumbsup:
Iranch High-End Tricycle (A64119)
Iranch High-End...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A64280)
2016 FORD F-550XL...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2017 Ford F-450 Liftmoore 5000W 5,000lb. Crane Service Truck (A61573)
2017 Ford F-450...
