2150 Orbital Valve Breaking Bolts
   / 2150 Orbital Valve Breaking Bolts #1
NPresley
John Deere 2150
I have an '87 JD 2150. The orbital valve has snapped 3 of the 4 square flange mounting bolts. I assume the valve needs rebuilding and the bolts replaced, but what would cause the bolt heads to snap off? Could the valve have a blockage that would create that much pressure?
-Nathan
   / 2150 Orbital Valve Breaking Bolts #2
Welcome to TBN
What valve on a JD 2150 are you referring to as the orbital valve? I suggest to check tractor hyd stand-by pressure which should be 2250 psi. Stroke control valve in front hyd pump is what determines 2150 hyd system pressure.
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2020 Bobcat E35I Mini Excavator (RIDE AND DRIVE) (A50774)
2020 Bobcat E35I...
2016 FREIGHTLINER 2500 SPRINTER VAN (A52141)
2016 FREIGHTLINER...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
