2140 john deere
/ 2140 john deere #1
brendan1
JOHN DEERE 2140 X-E SERIES
Hello everyone i am new to this forum.
Looking for some help working on a 2140 X-E SERIES.
There is oil leak from the shaft that goes through the rear housing for the lift arms my question is can this shaft be pull out to put in a seal or is there something on the inside of it?
Has anyone any manual, diagram or picture would be much appecated.
Regards
Brendan.
/ 2140 john deere #2
:welcome:
Have you looked at jdparts? Need to register, but it is free. Lots of good information there when looking at the parts breakdowns, and part numbers.
Here is a pic of a breakdown of the rockshaft and lift arms. Don't see any seals so am wondering if this includes what you are asking about.
/ 2140 john deere
Thanks
But it is the bottom shaft .the one the arm come of.
Regards
Brendan.
/ 2140 john deere #4
brendan1
Ok, but not sure that is a shaft that comes out, if I follow you.
Will this pic help, and is this what you mean?
/ 2140 john deere #5
Bottom shaft is the torsion bar and these seals are a frequent problem with JD's
/ 2140 john deere #6
:)I'm curious now, as there is no torsion bar listed in jdparts for the 2140.
Do you by chance have a breakdown of its location and part number? thanks
/ 2140 john deere #7
The shaft he is referring to is a torsion bar that will bow ever so slightly in propertion to the draft load. It does have a lever attached to it that adjusted the hitch valve, this is part of the load and depth control feature. Seems like all of these leak a little that I have seen.
No, it does not come out easily, it is attached in the middle of the shaft.
/ 2140 john deere
Does anyone know how to replace the shaft?
Thanks For The Help!
Brendan
/ 2140 john deere #9
John Deere - Parts Catalog
Printer Friendly Page
Close Window
Catalog: 4185 | Grid: 3L11 | Section: 71 | Page: 80
Catalog Name: 2140 Tractor (430000- )
Page Name: PARTS FOR LOAD CONTROL (WITH INCREASED LIFTING CAPACITY)
Direction of Travel:
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 R72653 SNAP RING 2
2 L56824 SET SCREW 1 1/2"X1-1/2"
3 14H856 NUT 1 1/2"
4 AL61479 EXTENSION 1 (SUB FOR AT30631 APPL)
5 34H394 SPRING PIN 1 3/16"X15/16"
6 L55223 FOLLOWER 1
7 R49962 EXTENSION SPRING 1
8 T24690 PIN FASTENER 1
9 L58389 LEVER 1 (SUB FOR L39881)
10 T21680 PIN FASTENER 1
11 T19687 O-RING 2
12 AL40773 FLANGE 2 (ORD L41196, T28545)
13 L41196 BUSHING 1
14 L41198 SEALING WASHER 2 (SUB FOR L55844)
15 19H1708 CAP SCREW 4 5/8"X1-3/4"
16 L41819 SHAFT 1
17 T30917 PIN FASTENER 1
18 T30918 PIN FASTENER 1
19 A4365R O-RING 1
20 14H882 NUT 1 5/16"
21 19H3120 CAP SCREW 1 5/16"X1-1/2"
22 T21681 DOWEL PIN 1
23 T28545 SUPPORT 1
Brandon
I was wrong about the pall being connected to the shaft, it only contacts the shaft when flexing. I would think you can change the seals on the ends if you are willing to drain the case.
Hope to post a pic for you. If you go to the section above you can see an illustration that will be helpful to you.
/ 2140 john deere #10
Thanks for pinpointing the location of this shaft.
Might also change out the 0-rings. Looks fairly easy to do.
Looked it up, and here is illustration.
/ 2140 john deere #11
There are a couple of variations depending on the model, but they are all similar. Some have the flanges on the ends, some don't but they all have seals and/orings to refresh.
