2120 Cavitating
   / 2120 Cavitating #11
Scott,
If you see foamy/milky oil the problem is like you said "air entrainment" and it gets sucked in from an N/G or loose suction line/tubing, or it could be a leaky shaft seal on the pump......clogged suction strainer/filter or oil too thick will compound this condition.....
Best to check all connections and glob grease on the shaft seal if it's out in the open.....
It's rare to have the cyls introduce air as it would need an overrunning load to create suction to have this happen.....
I'd double/triple check all suction connections/piping/hose before proceeding....:thumbsup:
   / 2120 Cavitating #13
I'd unscrew the hydraulic filter and check the O-ring. The filter is vertical on that machine so it shouldn't spill much oil. Check the piece of flex hose and band clamps just before the filter as well.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
IH 470 Disk (A50515)
