210 question
/ 210 question #1
BowlBuilder
Martinsville, IN
1985 Case/Ingersoll 448
I've always liked and wanted a Case 210, but ten horsepower seems a little on the low side. Would a 14 h.p. engine from a 224 (or 444) be a direct bolt in for the 210? I thought they might have used the same engine from the 220 for the 210 as a cost saving measure. If so, how would the Peerless transaxle hold up to the extra horses? My property is very hilly and I would love to have one for use as a mowing machine and nothing more. Thank you.
/ 210 question #2
My understanding is that Case used the exact same spec in the 210 as in the 220. There is a pulley on the stub shaft of the Kohler and that drives a V-belt connected to the Peerless trans-axle. That trans-axle is pretty rugged so I see no reason to not drop a K-321 in the frame. After all, the engine is going to power a deck and you could then install a 48 inch deck, thanks to the engine power change. When mowing grass, the 14 HP isn't going to strain the trans-axle any more than the 10 horse motor will. Whatever torque is needed to propel the tractor isn't going to increase just because you installed a different engine. Go for it. A lot of people love the 210.
/ 210 question
Thank you very much, that's the answer I was hoping to hear. I will be keeping my eye out for one. Hopefully with a bad motor.
/ 210 question #4
Just be sure that you get one that is 100 percent complete. Having a weak motor is OK but you want the tractor to have a motor so that you have everything you need to change over to the K-321. You don't see that many 210's being parted out and you don't want to have to buy new parts.
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
ATS Mini Excavator (A66408)
ATS Mini Excavator...
3143 (A63117)
3143 (A63117)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
