2050 Mits
/ 2050 Mits #1
oliver28472
Veteran Member
Mt. Ulla, NC
Satoh S-470D, Mitubishi FD 1450D
1. A friend has one and I think his glow plug indicator is toast but the plugs are still working. Is that possible? I thought the power went through the indicator.
2. Is there a non grey mits or satoh that uses the same starter switch as this tractor?
/ 2050 Mits #2
I have a D2300 and my indicator doesn't ever glow, but the plugs both heat. Fires up right away, even on these cold (relative, I understand!) winter ones... The indicator is very corroded and I suppose I'll replace it one day, but as long as it works...
/ 2050 Mits #4
Regarding - Is there a non grey mits or satoh that uses the same starter switch as this tractor?
I replaced my D2050 starter switch with a Kubota part. Don't recall the number but I took my switch to the Kubota dealer and he found one that looked exactly the same. It installed with no problems and worked fine.
