2030 loader Hyd Connection
/ 2030 loader Hyd Connection #1
jpep
Manchester TN.
JD 2030
I have a 70's 2030, currently my loader is running off of my rear remotes.
I would like to move the connection so I can use other implements, can anyone tell me where to tap the pressure and return lines??
Maybe a picture or two??
/ 2030 loader Hyd Connection #2
This picture gives you a general idea. You will need a ported filter cover. Your return line connects to the filter cover. The pressure line gets teed into the pressure line under the right step that feeds your scv (rear remote) valve. The steel line now connecting to your scv and leading under the step, gets replaced by hose #1 and parts 5 - 15 and hose #30. The return hose from the loader valve is #29 and connects to the ported filter cover. The pictured tee at the cover is not necassary unless you have something else already connected there.
Sorry for the late reply, I have been on vacation.
Thanks for the info, I'll study the Pic. and if/when I have questions I'll get back..
