2028 century hydraulics quit working
   / 2028 century hydraulics quit working #11
Didnt know if i wanted to tear it apart if i couldnt find another pump if i needed it
You're better off yanking it apart on a scouting mission if it's dead anyways
   / 2028 century hydraulics quit working #12
Have you checked the suction hose.
Perhaps you lost the prime.
thanks for your input will take pump off as it is on outside of motor in front easy to get to but sometimes looking at it and actually getting it off can be two different things i will look at suction hose first though before tearing it apart thanks guys
:confused2:Well took pump off it turns although is very stiff and feels kind of like is grinding put back on and if put fluid in hose and let it feed it works after hooking feed line on it doesnt work . Seems like it isnt pulling fluid from reservoir to feed could the suction be out? and if so probably need new pump right? i've done everything i know of to make sure there are no blockages in feed line and i'm pretty good at taking this thing apart now thanks:confused2:
   / 2028 century hydraulics quit working #15
If you remove the suction hose, does the tank try to drain?
Is your suction hose good from tank to pump IN port?
If you have a screen in the hyd system, remove it , clean it and replace.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2023 BOBCAT T76R SERIES SKID STEER (A51242)
2023 BOBCAT T76R...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
Work Saver 3 pt Post Hole Digger (A50515)
Work Saver 3 pt...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
