2023 Mule Pro MX EPS?
   / 2023 Mule Pro MX EPS? #71
The link is for 4 x 156mm bolt pattern wheels for a Pro FXR. I believe the Pro MX uses 4 x 136mm.
Only the pro mx KAF700A series uses 4x136. The KAF700B, C, and D all use the 4x156 bolt pattern. Can be very confusing because many aftermarket companies don't differentiate models
   / 2023 Mule Pro MX EPS? #72
I see thanks Buckeye!
The right side of my MX appears to be about 1/2" higher than the left. I'll run the left side F&R springs up to level it.
Couple more of my favorite Mule. I love taking pics and this is just another reason to get out with my camera.
   / 2023 Mule Pro MX EPS? #74
Looking good. (y) We used real cameras as well. You guys sure don't have much snow there. Less than normal this year?
   / 2023 Mule Pro MX EPS? #75
It looks nice in camo, and so complete! First thing I did was remove the roof and doors.
I did level mine today. Puffed all tires to 12psi then increased preload on left front and left rear until level.
Been a easy winter here south of Buffalo. We usually get hammered.
I was going to remove the doors but those Carnivores really kick up the mud.
   / 2023 Mule Pro MX EPS? #78
I'm not a fan of the doors either bit keeps mud off....to a certain degree. I like the roof and I added a windshield.
I am gonna take the bars off the cab so I can reach into the bed though
   / 2023 Mule Pro MX EPS? #79
I noticed that when looking at your wider tires and wheels and can see that happening. I get no spray, dirt, or mud with doors off with stock tires so that's why the doors have stayed off. But the P520 (stock) tires sprayed everything from the road on my leg so those doors went right back on.
CAT 930M (A58214)
CAT 930M (A58214)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
1454 (A57192)
1454 (A57192)
